ClementN
#1 Posted : Thursday, September 3, 2015 8:37:53 AM(UTC)
ClementN
Romania
I am trying to add a shortcut in v16 to set a certain input to Fullscreen ( SetOutputFullscreen function)
No syntax seems to work for me in the Value field of the shortcut.
I tried: Input=2 , Input2, Input="2", 2 etc
Nothing. Each time the Preview is assigned instead of the needed Input.
The "Output" and "MultiView" is working.
Any advice?
Thank you,
richardgatarski
#2 Posted : Thursday, September 3, 2015 10:38:10 AM(UTC)
richardgatarski
I have tried to figure it out too, but can't get it to work (16.00.65)
#3 Posted : Thursday, September 3, 2015 11:14:56 AM(UTC)
Was thanked: 1017 time(s) in 835 post(s)
A little confused
Trying to set an input to fullscreen with SetOutputFullscreen ?
ClementN
#4 Posted : Thursday, September 3, 2015 11:17:13 AM(UTC)
ClementN
Romania
doggy wrote:
A little confused
I want one of the inputs to be shown in the Fullscreen. In fact, I need a shortcut set-up for that.
migueis
#5 Posted : Thursday, September 3, 2015 4:10:06 PM(UTC)
migueis
ClementN wrote:
doggy wrote:
A little confused
Same problem here.
migueis
#6 Posted : Thursday, September 3, 2015 4:19:45 PM(UTC)
migueis
I have find a workaround to that problem:
First, click the Add button
- Before select the function, change the input to the input you want to display
- Then set the key and the function to the desired key and SetOutputFullscreen and no need to set the value
Check it now ;)
Ernest Król
#7 Posted : Thursday, September 3, 2015 4:56:06 PM(UTC)
Ernest Król
You can also use "StartScriptDynamic":
Code:
Function=SetOutputFullscreen&Value=Input&Input=n
where 'n' is the input number :)
ClementN
#8 Posted : Friday, September 4, 2015 1:01:47 AM(UTC)
ClementN
Romania
Very nice work-arounds.
Thank you very much!
#9 Posted : Friday, September 4, 2015 8:57:31 AM(UTC)
Was thanked: 4674 time(s) in 1609 post(s)
Just updated vMix 16 to version 16.0.0.67 which fixes the hidden input box bug for this shortcut.
migueis on 9/4/2015(UTC), ClementN on 9/4/2015(UTC)
ClementN
#10 Posted : Friday, September 4, 2015 12:01:01 PM(UTC)
ClementN
Romania
admin wrote:
16.0.0.67
* SetOutputFullscreen will now accept input names through API
Hello Martin,
In another post you explained why you prefer to use Input number instead of input name for Fullscreen output .
Is anything changed ? If we use Input name is there any trade with the CPU resources or you still recommend the use of input number if possible ?
Thank you very much,
#11 Posted : Friday, September 4, 2015 12:04:38 PM(UTC)
The shortcut will find the number for that particular input and then set that to fullscreen.
This means that if you move the input around, the fullscreen will still stick to whatever input is in the original number position.
ClementN
#12 Posted : Friday, September 4, 2015 12:07:14 PM(UTC)
ClementN
Romania
Thank you for explanation.
Very good solution. Thank you!
Clement
migueis
#13 Posted : Friday, September 4, 2015 3:05:56 PM(UTC)
migueis
I think i did not understand. So, you are telling that is good to use name instead of number?
migueis
#14 Posted : Friday, September 4, 2015 3:10:24 PM(UTC)
migueis
I have another problem with SetOutputFullscreen function.
I have an input (a video) and set a trigger OnTransitionOut or OnCompletion, SetOutputFullscreen to an input but it does not work. No action!!!
#15 Posted : Friday, September 4, 2015 10:22:05 PM(UTC)
Triggers only supports basic shortcut functions that do not require Value to be set, so SetOutputFullscreen
won't work.
Not sure why you would need to use this with a trigger though? You should use the normal switcher functions to change the output.
migueis
#16 Posted : Saturday, September 5, 2015 7:00:22 AM(UTC)
migueis
won't work.
I have a projector in an auditorium that functions as a second monitor. I want the videos to pass this projector and when the video ends and the mix change for a camera, the projector must display an image that is another input.
To do that e uso the function SetOutputFullscreen
