WilliamCole
#1 Posted : Wednesday, September 2, 2015 3:25:45 PM(UTC)
WilliamCole
Hi, I have two questions. Does VMix work with windows 10. I am currently upgrading the system I use it on. Also for video cards I currently have a 1gb Ge Force is it worth it to upgrade to a Ge Force 750 2gb. Will I see any difference with Vmix or is 1GB sufficient?
rrpro
#2 Posted : Wednesday, September 2, 2015 4:05:43 PM(UTC)
rrpro
