Joined: 8/9/2015(UTC) Posts: 12  Location: Hereford,UK
Just been testing vMix but having problems.
I have a Blackmagic Ultrastudio Monitor ( thunderbolt) that is plugged into my Blackmagic ATEM TVS vision mixer, I'm using this as the output from my computer. vMix is playing the video fine on screen but not outputting via the Ultrastudio. I know the Ultrastudio is working as I get output using Blackmagic media express. So I'm guessing it must be a settings issue, I'm SD widescreen.
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ Iris
This might be a stupid question, but have you enabled "External Renderer" in vMix and matched the settings for Ultrastudio to recognize it? (One of my 'pet peeves' with Blackmagic products, so friggin temperamental with settings, I can only assume Ultrastudio is no different and needs to be configured in the BMD Control Panel)
IceStream wrote:@ Iris
Ice Of no assistance, but I just avoid their products now. They might made some awesome other gear that doesn't involved interfacing to a computer, but the stuff that works with a computer is often close enough to working to completely frustrate you, but is so fussy will eventually drive you nuts thinking there has to be something easier :) I've wasted that much time with GoPros and BM Capture the best advice I could give myself is never buy BM Capture equipment. Since switching to alternative equipment my headaches just went away.
Making some progress........ I think!!!
I'm getting audio out but no video, when I click on ext output I get an error box
StartStopExternal Access is Denied. (Exception from HRESULT : 0x80070005 (E_ACCESSDENIED))
I'm running the trial version while I test it, should I be able to playout video files.
Playout is working in BM media express so everything is working outside of vMix
