Lzrd
#1 Posted : Friday, August 21, 2015 5:10:40 AM(UTC)
Lzrd
I'm looking for motherboard for Intel Core i7-5820K (LGA 2011-v3)
I will use these cards:
PCIe 3.0 x16 - Gigabyte GeForce GTX 960, 4GB GDDR5
PCIe x1 - AverMedia AVerTV Nova T2+C
PCIe x1 - MAYA44 Xte
PCIe x1 - DeckLink Mini Monitor (4 lanes?)
PCIe x1 - DeckLink quad (16 lanes?)
I'm not very familiar with CPU/MB lanes and want to know if I have no problems with motherboard like this:
40-Lane CPU-
3 x PCIe 3.0/2.0 x16 (x16, x16/x16, x16/x16/x8) *1
28-Lane CPU-
3 x PCIe 3.0/2.0 x16 ( x16, x16/x8, x16/x8/x4) *2
1 x PCIe 2.0 x16 (x4 mode) *3
2 x PCIe 2.0 x1 (x1 mode) *3
1* The PCIe x16_4 shares bandwidth with M.2 x4. When M.2 socket is occupied, the PCIe x16_4 slot will be disabled.
2* The PCIe x16_4 shares bandwidth with M.2 x4. When M.2 socket is occupied, the PCIe x16_4 slot will be disabled.The PCIe x16_3 slot support x8 devices only.
3* The PCIe x16_2, PCIe x1_1 and USB3_E56 connectors share the same bandwidth. By default, the PCIe x16_2 slot and PCIe x1_1 slot will automatically run at x1 mode with USB3_E56 enabled for best resource optimization.
Or this one?
Lzrd
#2 Posted : Saturday, August 22, 2015 7:33:16 AM(UTC)
Lzrd
So would there be enough lanes for all my cards?
#3 Posted : Saturday, August 22, 2015 1:23:41 PM(UTC)
@ Lzrd
That's a fairly technical question on the computer engineering side, and probably beyond the 'expertise' of most users on the forum (and those that are "in the know" might have a vested interest in not wanting to 'share' that information).
Both those boards appear to be pretty "cutting edge" and one would expect there to be no issues, but sometimes 'advanced features' can come at the expense of 'conventional' and/or specific functionality that the boards are not designed for.
I would suggest contacting the manufacturer (ASUS) and seek their professional advice as to what they would recommend for your specific needs.
They may or may not be able to help, but it's worth a shot.
Ittaidv
#4 Posted : Tuesday, August 25, 2015 8:48:38 PM(UTC)
Ittaidv
40-Lane CPU-
28-Lane CPU-
Or this one?
Blackmagic cards use 1 lane for a single 1080 stream. so a decklink mini recorder or an intensity pro, use a single lane.
A 4K card uses 4 lanes, so does a quad 1080 card. You can easily check for this by using the desktop utility of Blackmagic, and creating a status report in the 'about' tab.
If you have 6 slots, and on each a 4 lane card, you get 24 lanes, add your graphic card with 16 lanes and you will have 40 lanes used. This could give you 24 HD inputs.
That's theory, because most motherboards will cut corners somewhere and your system uses some pcie lanes for other things as well. Watch out for PLX chips too, they're made to route the traffic but can do terrible things with live video.
I once posted here somewhere a breakdown of a system that is sold by livestream.com. you can find the hardware they used over there. Except for the weak video card, you could use the same motherboard and be safe.
We now own a second system with a 40 lanes xeon, but the quad cards lock up for some mysterious reason, that's why we didn't finish it yet. It must have to do something with the motherboard, but after checking multiple times, we never found the reason. until we can find the reason, we won't finish it. stupid, since we spent a lot of money on the hardware. In theory the motherboard should handle it, but in practise it locks up with quad YUAN cards. Strange, because our 16 lanes system handles them just fine. I'm just saying this, because computers can sometimes do crazy things that are not explainable with just theory :)
It's safe to say you should never push a system to its limits lanes whise. Your setup should be fine in theory, any modern board will take these 6 HD inputs. We ran tests on an i7 2600k (16 lanes) and it could handle 5 HD inputs and run stable, 6 made it a little unstable, although it was sending the video, if we started recording and streaming the system would hang a little.
We had good results with ASUS and MSI motherboards, an Asusrock one is failing on us right now though. No idea if it's the brand, the design, ..
hellokitty
#5 Posted : Saturday, August 29, 2015 11:22:04 PM(UTC)
hellokitty
if you can, get the intel 5930k so you got 40 lanes, i just got this board http://www.asus.com/Moth...ds/RAMPAGE_V_EXTREMEU31/ based on it's loaded. Asus has the best boards and support and if you get a ROG board it has its OWN website with lots of info, and Asus supports these boards the most frequently with new Bios Updates and features.
