Len56
#1 Posted : Tuesday, July 28, 2015 2:19:46 PM(UTC)
Len56
Is anyone using Adobe Premiere Elements 13 and had success in looping a video?
I want to be able to use 30 seconds of a video I recorded and use it as a looping background in vMix.
If anyone has had success in looping a seamless video can you tell us how to do it please as I have tried but I'm getting the video jolting as it goes from the end back to the beginning on the video, if that makes any sense.
Thanks.
Len56
#2 Posted : Tuesday, August 4, 2015 9:27:03 AM(UTC)
Len56
Is anybody out there?
my post has had 63 views, is anyone using Adobe Premiere Elements out there and has an answer to my question.
#3 Posted : Tuesday, August 4, 2015 10:45:47 AM(UTC)
@ Len56
Although I am not familiar with Premiere Elements, it is probably not that different from Premiere Pro for doing simple edits, but I am not exactly sure what your having problems with.
What is the nature of your 30 second video?
In order to have a 'seemless' looping video, the last frame of the video has to 'match' or lead into the first frame of the video.
You can sometimes overcome a 'jump cut' by using a dissolve transition between multiple instances of your clip (i.e. 10 x 30 seconds = 5 minute clip) but eventually you'll need to restart the video and the 'jump cut' will show.
Alternatively, you might be able to 'reverse' the playback of the second instance (i.e. 2 x 30 seconds = 1 minute clip), although I am not sure if elements has this feature or if your video is conducive to that.
Can you elaborate a little more?
(BTW, I have successfully done similar extended looping video clips this way)
Len56
#4 Posted : Wednesday, August 5, 2015 10:34:16 AM(UTC)
Len56
Hi IceStream,
Tanks for getting back to me.
See below for a screen shot of my 30 second video.
I will be using the video as a moving background with a overlay of a person on camera in front of it.
I have looked up on the net regarding premiere pro and that does do looping of videos but premiere elements does not.
The video is 1080i and is about 2 minutes long but I thought running a video that long will use quite a bit of the CPU process especially with a person on camera in front of it, that is why I cut the video down to 30 seconds plus the person on camera could be on view for at least 30 minutes at a time, also I saved the video as a .MOV file. What would you say would be the best video format to save a video in for the best results in vMix regarding low CPU usage?
I will have a try at your suggestions in your 3rd and 4th paragraphs and I will report back.
Len56 attached the following image(s):
New Picture.jpg (41kb) downloaded 0 time(s).
#5 Posted : Wednesday, August 5, 2015 8:24:17 PM(UTC)
@ Len56
"Live" footage is the issue...
Wind, waves, clouds and background items can change over time and with any kind of camera movement or displacement, it will be next to impossible to match the first and last frames of your video clip.
I would keep the full 2 minutes and in fact add 3 or more instances of it in elements and do a slow dissolve between clips (just enough that it isn't obvious, depending on just how 'different' the first and last frames are) and make a 6 or 10 minute clip (even the full 30 minutes if necessary), CPU usage should not be a factor since you are playing video regardless of looping or not.
You can also experiment with the playback speed as long as it is not noticeable (50% speed will give you twice the duration)
'Reverse' will likely not work in this instance as the waves/water movement will be noticeable.
You should be fine with .MOV or .AVI files if you have the space, but there should not be an issue with using .MP4 either, if you have the time, I would experiment with a couple different scenarios to see what works best for you.
A 30 second loop may be too short if there are any distinguishable occurrences in the background (like a gust of wind or a bird flying by).
Just my thoughts.
Len56 on 8/21/2015(UTC)
Len56
#6 Posted : Friday, August 21, 2015 11:51:57 AM(UTC)
Len56
IceStream,
Thanks for your input, you have given some great ideas.
Thanks again.
#7 Posted : Saturday, August 22, 2015 1:03:49 PM(UTC)
@ Len56
You are most welcome, keep us posted as to how you make out.
