3rd Party Software and Development
SetOutputFullScreen does not work in HD licence?
Joined: 8/5/2015(UTC) Posts: 16 Location: Milton Keynes,UK
Hello once more API "SetOutputFullScreen" and "SetOutputFullScreen2" worked in the trial version. Having paid for it though, the HD version, these no longer do anything when sent from a remote PC. for instance http://192.168.90.180:8088/API?Function=SetOutputFullScreen&Value=Output used to change the output to view to ouput (or preview/an input), now it has no effect, but returns an OK message. Am I missing something? Many thanks.Geoff
Joined: 2/9/2013(UTC) Posts: 264 Location: Katy, Texas
Its possible the features you are wanting are not available in the HD version. Are you able to achieve the desired result directly from the vMix computer in the HD version?
 1 user thanked Kelvin for this useful post.
Joined: 3/7/2012(UTC) Posts: 2,688  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ Geffers
I think this might be in the wrong section (not related to 3rd party software at all) Never-the-less, the API should function the same across all editions (excluding requests for unsupported functions of a particular edition, in this case "Output2" which is only supported in 4K and Pro) The instance you specify though for "Output" appears to work fine for me in vMixHD (from the same PC) so I am not sure if your issue might be related to connectivity problems with the remote PC. Are you sure you have the right address? This can sometimes change from set-up to set-up depending on the network status over time (but you probably already knew that). Can you elaborate as to what other calls may not be performing as expected?
Thanks for your replies. I think I've concluded that since the same thing worked on the demo version, it must simply be a version thing. And yes we can control the output from VMIX, so for now that will have to do. Geoff.
