Geffers
#1 Posted : Tuesday, August 18, 2015 7:29:30 AM(UTC)
Geffers
Please can you reply to our (K Goodyer and myself) questions about the API.
Many thanks
Geoff.
#2 Posted : Tuesday, August 18, 2015 8:04:35 PM(UTC)
@ Geffers
Hi Geoff, if you are referring to the question in this post:
http://forums.vmix.com.a....aspx?g=posts&t=4997
The 'Transition 1-4' refer to the four customizable dropdown transition buttons between the 'Preview' and 'Program' screens.
So whatever parameters you have set for those 'dropdowns' (when you right click them)
Will be 'parameters' used in either API or 'Shortcuts'
I hope that helps.
P.S. Have patience with Martin and his team. He can't possibly address every question or issue, especially when a lot is explained (maybe not always clearly or thoroughly) but explained none-the-less in the help documentation
http://www.vmixhd.com/he...dex.htm?Transitions.html
And with a little curiosity and adventure can be figured out by playing around with things. I know that is not always convenient, but it really is the best way to learn the software.
Geffers
#3 Posted : Thursday, August 20, 2015 6:11:16 AM(UTC)
Geffers
Thank you for the reply.
Yes, it seems like that API doesn't have a facility to do quite what we want here.
Geoff.
#4 Posted : Thursday, August 20, 2015 10:58:50 PM(UTC)
@ Geffers
What exactly is it that you want?
