msburg
#1 Posted : Monday, October 11, 2010 7:15:23 PM(UTC)
msburg
Dear...
Is there anyway to start vMix with the Fullscreen disable? I don't have 2 monitors. Everytime I start vMix, its default is Fullscreen. I'd like to start vMix without Fullscreen activated, I can then activate (enable) Fullscreen feature when I need by mouse click on it.
Thank you for your help.
Michael.
melody
#2 Posted : Tuesday, October 12, 2010 5:21:32 AM(UTC)
Rank: Guest
Groups: Guests
hi msburg,
think is not possible (please correct me if it is possible). however, precise the finality why you want fullscreen disabled.
I might be able to help you with another solution...
regards
melody
msburg
#3 Posted : Tuesday, October 12, 2010 6:22:23 AM(UTC)
msburg
melody wrote:
hi msburg,
regards
melody
When I start vMix, it took control of the display. I cannot start another application until I turn off the FULLSCREEN mode. If I connect a second monitor, the second monitor goes blank (black) until I turn off the FULLSCREEN mode. I think vMix should have allow the user to select/set FULLSCREEN mode upon starting vMix through command line switch or through ini file.
Thanks.
Michael.
melody
#4 Posted : Tuesday, October 12, 2010 7:20:29 AM(UTC)
Rank: Guest
Groups: Guests
maybe you have some graphic card misfits. try to configure your graphic card correctly... what model of your graphic card by the way?
#5 Posted : Tuesday, October 12, 2010 1:05:12 PM(UTC)
This option will be available in the next version.
melody
#6 Posted : Tuesday, October 12, 2010 6:23:40 PM(UTC)
Rank: Guest
Groups: Guests
hi martin, thats great...
apparently the new version of vmix promises to be more stable and efficient with the new changes.
martin is working hard ... I'm waiting for the new version of vmix.
