vMix Beta 10 DV/HDV Support Added
I see that DV/HDV Support Added, is this through capture? I don't see it in the input list.
Joined: 1/13/2010(UTC) Posts: 5,326  Location: Gold Coast, Australia Was thanked: 4729 time(s) in 1621 post(s)
Yes, the DV/HDV devices should appear in the Capture list under the Capture tab.
I did not notice the dv/hdv option in the capture list either. Also I am not able to get the audio to work. When I open the mixer one or more of the volume controls is grayed-out. I have attempted to run the program on two different systems to no avail. Please let me know if there is an adjust I need to make. Thanks.
What options do you currently have in the capture list? Make sure the DV/HDV device is correctly working through other capture programs first.
With regards to audio, what audio functionality is not currently working?
