Joined: 1/21/2014(UTC) Posts: 83 Location: sportwebtv.be
Thanks: 15 times Was thanked: 1 time(s) in 1 post(s)
Hi
Yesterday we streamed a hockey match. Was horrible :-( .
We have a one pc solution Intel Core i5, Intel 4570 / 3.2 GHz, 1 TB SSD an 12 GB RAM and e Decklink quad 4 SDI inputs.
Yesterday we used 3 sdi inputs, replay only of the output (program) , record with 1080 / 20Mb/s . Upload with 720 / 25fps and 1.8 Mb/s.
Obviously running all this feature together was too much for our pc. The programm haltingly extrem.
What do you think was the problem?
Thanks for feedbacks.
Patrick
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
Hi Patrick,
What graphics card is used in the PC and what version of windows installed? When using vMix keep an eye on both Render Time and CPU at the bottom of the window. If the Render Time is over around 20ms, it means the graphics is overloaded, if the CPU is over 70% it means the CPU is overloaded.
Martin vMix
Hi Martin
I have Windows 8. Is it in General possible that replay, cam mixing, record with full hd 3mb bitrate is done with a single CPU. Vor what setting would you recommend?
Best, Pat
