kgoodyer
#1 Posted : Thursday, August 13, 2015 7:07:09 PM(UTC)
kgoodyer
Was thanked: 53 time(s) in 27 post(s)
All
Can anybody tell me if its important as to which Direct Show Decklink device is selected for Inputs. For each Decklink channel (and I have eight of them) you are presented with three possible choices for each Decklink input.
1 - Blackmagic WDM Capture
2 - Declink SDI
3 - Decklink Video Capture
Does one perform better than others? Are there advantages to one over another? are they just the same thing with three different named entries?
All The Best
Keith
Ittaidv
#2 Posted : Friday, August 14, 2015 11:28:43 PM(UTC)
Ittaidv
I know WDM capture should be picked with some gopro's when the aspect ratio is not right, and some options have the option to exclude bringing in the audio. I don't think there's big differences in performance though.
thanks 1 user thanked Ittaidv for this useful post.
kgoodyer on 8/14/2015(UTC)
Slaver
#3 Posted : Saturday, August 22, 2015 8:11:28 AM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
I always have the best pictures with the second option "Decklink SDI" or "Decklink HDMI"
And i heard something about limited Resolution with WDM Capture.
