acombs1793
#1 Posted : Wednesday, August 12, 2015 11:21:59 AM(UTC)
acombs1793
I have about 6 different video feeds and everything is working great but I can not figure out the audio. I have a wireless mic system into a mixer then into the computer. It comes up fine and adjust the delay. Heres my problem. I want that audio being heard over every feed. I dont want it as a separate audio feed that I have to switch to, to hear. How can I have the audio input at all times?
Bardos
#2 Posted : Wednesday, August 12, 2015 11:30:19 AM(UTC)
Bardos
Groups: Guests
Go into settings, Under 'Audio' deselect the check box for: 'Automatically Mix Audio'...That should solve your problem......
cirkusborly
#3 Posted : Wednesday, August 12, 2015 3:45:36 PM(UTC)
cirkusborly
HI
When yoy setup the videofeed you shall choose audio to none. When you do that you will only have the video. Then you should set up the audio as master and secure that nothings happens when you change between the different videofeeds.
