Iris
#1 Posted : Wednesday, August 12, 2015 4:08:10 AM(UTC)
Iris
Hi, I've done a search about the "List" or "video List" Function. I'm presuming this is a VT file play out option?? if so what file formats does it accept? the manual talks about M3U? is that the file format it converts too? not herd of it before. What files will it play out?
Many thanks
#2 Posted : Wednesday, August 12, 2015 10:09:19 AM(UTC)
@ Iris
Basically, any video file that you can play and/or input into vMix can be added to a "List" (virtually all formats).
I suggest you experiment and play with the possibilities to get a better understanding of how it all works.
As far as M3U is concerned, it is basically a link or list of links to 'on-line' content (search IPTV and m3u).
Hope that helps.
