Code4Sale
#1 Posted : Tuesday, August 11, 2015 10:25:25 PM(UTC)
Code4Sale
Hiya Martin!
I know there is an Append option after the open dialog for presets, but apparently, the users here are stupid, and we all end up clicking "Open" by mistake...
And it blows away our current setup. Not good during a live capture :(
Even a "you sure you want to do this?" dialog would be very helpful.
Somehow, we feel a dedicated "Append" Preset Button is very much worth the screen real estate on the main screen.
It should be very easy to code up as well.
And For us dummies, more important than the a "Last Preset" (who can remember what that was?) might be a "Last Settings Used" (an undo for open/append)
Just our 4.5 cents...
Thanks in advance for your consideration (and your hard work on the project)!
Joe and Lynda
