mclcmedia
#1 Posted : Tuesday, May 15, 2012 2:57:41 AM(UTC)
mclcmedia
Has anyone had success using vMix with Easyworship?
I can see the feed in the preview window of EW fine, but it just hangs if I try and GO LIVE.
I'd love to use vMix in our church auditorium but I just can't get it through EW. Help?
thanks 1 user thanked mclcmedia for this useful post.
ELCHAPIN on 5/15/2012(UTC)
#2 Posted : Tuesday, May 15, 2012 8:47:21 PM(UTC)
I am testing this at the moment. It is caused by the peculiar way EasyWorship uses capture devices.
I am trying to see if a workaround can be implemented without causing issues with other programs.
Will provide an update when I am closer to a solution.
ELCHAPIN on 5/15/2012(UTC), mclcmedia on 5/16/2012(UTC)
#3 Posted : Tuesday, May 15, 2012 10:07:20 PM(UTC)
I have found the issue and implemented a fix in the next release of vMix due soon.
ELCHAPIN
#4 Posted : Tuesday, May 15, 2012 10:47:08 PM(UTC)
ELCHAPIN
Thanks Martin
to add something like EASYWORKSHIP.
Long ago and requested.
in the PIP option circle, oval edge of dissolution
is what more and request, To give the best view to PIP or Videos.
Other than just pictures. only square not much profit.
all work is almost perfect in videomixers Soft.
Thank you.
Promoting in Latin America will continue your work at the websites
melody
#5 Posted : Wednesday, May 16, 2012 6:18:41 AM(UTC)
Rank: Guest
Groups:
thats great, thank you martin for this update.
so, here`s some requests:
1. is there any possibility to implement another external output virtual device? it would be important for people that want to use vmix to diferent tasks on same machine.
2. it is possible for vmix to show hardware information (CPU, GPU, RAM, HDD, MOBO, etc...)? sometimes it is hard to find.
3. countdown in preview window, before transition, based on a non looped video playing in program?
4. custom countdown timer before transitions? the idea is, after click on video source, preview shows video source and countdown information and then video source goes to program.
thank you for attention, regards,
melody
www.espiritosanto.cc
