15 Pages«<1112131415>
vedranius
#241 Posted : Monday, July 27, 2015 8:43:18 AM(UTC)
vedranius
bunayya01 wrote:
why vmix controller can't connect to vmix.. status always offline..
but in test port is responsive withe same port 8088..
thanks before
Same here. Did someone managed to fix this? I need this ASAP :)
Thanks!
wtmuradiotv
#242 Posted : Monday, July 27, 2015 5:22:56 PM(UTC)
wtmuradiotv
does not work for new version 15
wtmuradiotv
#243 Posted : Monday, July 27, 2015 5:30:24 PM(UTC)
wtmuradiotv
thanks before
Thanks!
[b
The program is a beta version that the developer abandoned awhile ago for reasons of other things ...Its a very well made program but is no longer supported ...Its a matter of someone taking it over and hoping they can follow out to get it to work for the newer versions seems it doesn't want to connect not sure what is blocked but that's what it is doing to me also !
#244 Posted : Monday, July 27, 2015 7:45:51 PM(UTC)
Just as a note, the program (alpha 0.7.14.102) still works fine for me.
Not sure what your issue might be...
Have you read through the entire thread?
Seems to me there was a similar issue early on, but I can't remember fully how it was resolved.
13 pages might be a lot of reading, but it might reveal something.
wtmuradiotv
#245 Posted : Monday, August 10, 2015 9:20:34 PM(UTC)
wtmuradiotv
AMP2TV wrote:
Not to hijack this thread but I thought I would post here.
After using the latest version of MacJaeger's controller, I found it to be quite unstable and a bit odd in some ways. Thankfully, he has kindly provided the source code, so I built a new version with some enhancements.
Download vScheduler
Most of the changes are in the controller, removing the connect button, and any sense of "connections." Mostly because the vMix api doesn't work that way. Small hiccups resulted in a "disconnect" which then would halt the schedule. This new version assumes vMix is running and the interface is accessible.
Aside from that, it also looks a little cleaner.
The manager also has a few nit-picky fixes, but otherwise functions exactly the same.
Source code is also available for those that would like to look at my changes: Source
Works great with version 16!!! Thanks keep up the good work
Georgewilliams
#246 Posted : Friday, September 25, 2015 9:25:35 AM(UTC)
Georgewilliams
How do I schedule an event daily, weekly, or monthly, or weekdays only?
Georgewilliams
#247 Posted : Friday, September 25, 2015 9:28:59 AM(UTC)
Georgewilliams
Len56
#248 Posted : Friday, September 25, 2015 10:10:48 AM(UTC)
Len56
Hi wtmuradiotv,
I just downloaded your version of vMix Scheduler and noticed the version number is 0.6.0.0, I have a the original version from MacJaeger and that is 0.7.14.102 have you been working on an old version of vMix Scheduler?
#249 Posted : Friday, September 25, 2015 10:48:06 AM(UTC)
@ Georgewilliams
AFAIK, there is no way to schedule recurring events other than manually.
Each occurrence of an event has to be scheduled independently in the vMixManager and subsequently pushed to the vMixController.
I hope that answers your question.
Georgewilliams
#250 Posted : Friday, September 25, 2015 3:11:23 PM(UTC)
Georgewilliams
Thanks Ice. Can this feature be added? It's kind of annoying to keep on adding events. At least if we can add event daily. Like every Monday, the same event, every Tuesday, etc..
#251 Posted : Friday, September 25, 2015 3:29:41 PM(UTC)
@ Georgewilliams
Unfortunately, the developer (macjaeger) has not been able to work further on this project, but has provided the source code earlier in this thread (not sure if it is still available or not) for others to proceed, which some have (ref. to wtmuradiotv posts above)
Georgewilliams
#252 Posted : Friday, September 25, 2015 4:48:46 PM(UTC)
Georgewilliams
Does Martin plan to implement this scheduler feature into vMix?
#253 Posted : Friday, September 25, 2015 8:14:17 PM(UTC)
@ Georgewilliams
You never know but my guess would be no as this app already exists and meets most of the needs of those who use it, besides, there are other commercial programs out there that are robust and built to do that.
But then again, if there is a large enough demand for this type of thing, I am sure the vMix team would consider it.
My best advice would be to make a "Feature Request" in the appropriate forum.
bunayya01
#254 Posted : Thursday, November 5, 2015 10:53:01 PM(UTC)
bunayya01
why vmix controler always offline sudden ..
the message is remote server returned to error..
Thanks a lot for the answer before..
sartori
#255 Posted : Wednesday, November 11, 2015 11:55:12 AM(UTC)
sartori
Boa Tarde! Como eu faço com o vMixScheduler para iniciar automaticamente o Streaming (StartStreaming), ou seja eu programo minha sequência de vídeo e fotos e gostaria de habilitar a opção de Streaming juntamente, existe alguma forma de fazer isso?
Damn2Good4U
#256 Posted : Thursday, November 19, 2015 3:13:56 PM(UTC)
Damn2Good4U
Does anyone know how to fix vMix Scheduler to work with Win10?
I just upgraded my PC to win10 and the vMix Scheduler is no longer working, I get this error when anytime i tried to push the scheduled videos to the vController from the vManager
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: String was not recognized as a valid DateTime.
at System.DateTimeParse.Parse(String s, DateTimeFormatInfo dtfi, DateTimeStyles styles)
at vMixManager.vMixEvent..ctor(XmlNode node)
at vMixManager.vMixManager.bn_append_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1038.0 built by: NETFXREL2
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
vManager
Assembly Version: 0.6.0.0
Win32 Version: 0.6.0.0
CodeBase: file:///C:/Users/FPtvOB/Downloads/vMixScheduler/vManager.exe
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
g-mo
#257 Posted : Saturday, November 21, 2015 2:21:21 PM(UTC)
g-mo
I'm going to be using the scheduler next week.
Got a question for those that use this often. Is there an easy way to add a big file (like a 2 hour film) and insert commercials at certain points?
ShadowGauge
#258 Posted : Monday, November 23, 2015 4:00:31 PM(UTC)
ShadowGauge
I just read 1 page so if i make it to the end and this is answered.. woohoo..but I cant get it to actually talk to vmix, as my IP differs from the IP the scheduler references, help.. also if you dont mind mr Mac.. letting me pick your brain a bit, that would be awesome... I just have a couple questions that should be easy for you to answer.. assuming I know how to ask them correctly.. I am sorta a newb when it comes to coding.. knowing pascal is not helping me at all..
w14
#259 Posted : Wednesday, December 9, 2015 10:13:52 AM(UTC)
w14
Don't think that's the reason. The controller is connecting to http://127.0.0.1:8088 or whatever port number is selected in its settings and in vMix. Even though vMix shows your main IP address in its settings, you can still connect to http://127.0.0.1:8088 in a web browser. So the controller should still work.
Ice - you had it working before. If you see this, could you check if it's still working for you?
Damn2Good4U
#260 Posted : Wednesday, December 9, 2015 12:28:48 PM(UTC)
Damn2Good4U
Yes
Guest (11)
