dundurs
#1 Posted : Monday, May 7, 2012 5:26:27 AM(UTC)
dundurs
Was thanked: 45 time(s) in 22 post(s)
Martin,
Would you mind telling where is shortcut configuration located? It doesnt seem to be saved in preset. Im looking for a way to migrate shortcut configuration from development to production system without changing the shortcut ids, which are assigned by vMix. At the end an external controller will be issuing http requests to vMix (really enjoying this latest addon in v3) to switch between inputs.
Dundurs
mh166
#2 Posted : Friday, May 18, 2012 4:22:05 AM(UTC)
mh166
Hi Dundurs,
* Press WIN+R and enter shell:local appdata (note the space..)
* open StudioCoast_Pty_Ltd
* open the folder starting with "vmix2012"
* finally in the folder representing your current version of vMix, you will find user.config
Here your settings are stored within this XML-document. Search for <setting name="Shortcuts" serializeAs="Xml">.
Hope that helps. :)
mh166
thanks 1 user thanked mh166 for this useful post.
dundurs on 5/18/2012(UTC)
dundurs
#3 Posted : Friday, May 18, 2012 6:43:03 AM(UTC)
dundurs
Thanks a lot, mh166! This is exactly what I was looking for.
Dundurs
