wiseguy
#1 Posted : Thursday, April 5, 2012 9:31:23 AM(UTC)
wiseguy
I trying to capture 3 simultanious videos from 3 Logitech HD c920 webcams.
I check the all 3 boxes in settings and press record, however there appears only one file (instead of 3 as I expected), with strange combinations of partly videos from all 3 cams, sometimes image is upside down.
I am on Windows 7 32 bit.
Am I doing something wrong?
#2 Posted : Thursday, April 5, 2012 11:28:34 PM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
What processor and graphics card are you running?
The MultiCorder feature requires a fast machine for best results.
wiseguy
#3 Posted : Friday, April 6, 2012 1:28:34 AM(UTC)
wiseguy
What are hardware min requirements for this recording option?
I've tried on latest Mac Mini with bootcamp/windows and Dell XPSM1530 laptop with the same results.
Is this a real reason to record only one file, not 3 different for each camera?
#4 Posted : Friday, April 6, 2012 5:37:48 AM(UTC)
Another possible issue could be the naming of each camera.
If they all have the same name then they could all be trying to record to the same AVI file.
To fix this, give each camera a unique name by double clicking the Title in vMix and trying the recording again.
wiseguy
#5 Posted : Saturday, April 7, 2012 6:25:12 AM(UTC)
wiseguy
I changed manually name of each camera, and now it records all 3 different avi files.
Only problem that they all are upside down.
Why?
When using simple Record function, orientationj of file is normal
#6 Posted : Sunday, April 8, 2012 8:53:24 PM(UTC)
I have fixed these two bugs in the latest test version, have a go and see if it helps:
http://forums.vmix.com.a...t.aspx?g=posts&t=352
wiseguy
#7 Posted : Monday, April 23, 2012 11:52:36 AM(UTC)
wiseguy
Latest version solved the isuues\
Thanx
