  Groups: Guests
                I like this ...great job....how soon can we see this for sale.....and, can it be used on the same PC as vMix as a floating window for times when only a single screen is used.....
 Joined: 1/25/2014(UTC) Posts: 50   Location: Bethel Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
                Any updates on this?  Is there a release date set yet?
 Joined: 2/27/2013(UTC) Posts: 312   Thanks: 8 times Was thanked: 78 time(s) in 43 post(s)
                Beloved wrote:Any updates on this?  Is there a release date set yet?  Hi Beloved, Sorry for the delay and lack of communication. We have been very busy with some exciting releases. We have some very exciting news we will be revealing next week on multiple vMix items for release. Stay tuned for an announcement next week!
                HOw's things coming along?
                Beloved wrote:HOw's things coming along?
   Great! We are waiting for the app to be approved by Apple. We will announce the release when we receive notice from Apple that it has been approved.
  Groups: Guests
                What about the control surface for the PC.....any news on that....
  Groups: Guests
                What about the control surface for the PC.....any news on how soon we can see this ....need this since I do not have an ipad, plus I want to use it on a two screen setup...
  Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
                Just downloaded for my Pad.  Good stuff.  Question however... The Tbar has a weird way of working. At teh top of the travel it snaps back to the original feed, not leavin on the feed you transitioned to.  Am I missing a setting?
                Runnriottt wrote:Just downloaded for my Pad.  Good stuff.  Question however... The Tbar has a weird way of working. At teh top of the travel it snaps back to the original feed, not leavin on the feed you transitioned to.  Am I missing a setting?  Good to hear you like the app! What wireless router are you using for your network? I have had some seemingly different results with some lower end routers. We are releasing an update soon that will add audio functionality as well as fix a couple bug issues. -Seth
                We were on a Belkin, N800 plus, but just changed to our ISP's internal router here in Japan.  Same thing on my home router and that is a new Mac router.
  If you go slow with the bar and not hit the top of the travel it works fine.  Just a bit to remember and to train on.
  I use this app when I am away from the computer.  I set it up to be a "remote" of sorts.  Chose 12 inputs that I need and now I can sit in the Sanctuary during Service.  I have even ran a camera and switched.  Love, love, love the ability to move.
                I did some more network testing with this app recently. I found that the network location needs to be set as "Home" or "Work" but not as "Public". If the network is set as Public, the windows firewall will block the incoming connection from the iOS app and it will not appear to connect.
  Groups: Guests
                Any update on the Windows version as yet.......I am waiting for that one, as I do not have an iPad....
  thanks
                thecloudmediagroup wrote:I did some more network testing with this app recently. I found that the network location needs to be set as "Home" or "Work" but not as "Public". If the network is set as Public, the windows firewall will block the incoming connection from the iOS app and it will not appear to connect.  I think you have to do a little software for the workstation, then this software connect directly to app... like a way or door.. because fail!
                mdsavio wrote:thecloudmediagroup wrote:I did some more network testing with this app recently. I found that the network location needs to be set as "Home" or "Work" but not as "Public". If the network is set as Public, the windows firewall will block the incoming connection from the iOS app and it will not appear to connect.  I think you have to do a little software for the workstation, then this software connect directly to app... like a way or door.. because fail!  We are utilizing the vMix API which accepts HTTP commands via TCP/IP. This is the only way to remotely connect to vMix. This is not a problem with our software but how the Windows Firewall handles HTTP traffic.
