Owensoundstudios
#1 Posted : Wednesday, July 8, 2015 9:32:44 PM(UTC)
Owensoundstudios
I'd like to generate a csv file or something to put a list for a leaderboard on screen over a custom graphic. I generate a csv, but it only picks up the first name in the list.
"Bob", 80
"Carry" 70
Anyone have ideas on how to make a leaderboard that grabs data from a txt file or anything?
Owensoundstudios
#2 Posted : Thursday, July 9, 2015 5:30:01 PM(UTC)
Owensoundstudios
Maybe if vmix is grabbing a whole list of different titles they could remain seperated by a CR and if it's supposed to be a list they could be seperated by a comma?
Kelvin
#3 Posted : Friday, July 10, 2015 9:36:12 PM(UTC)
Kelvin
Views messages in topic : 266
I've used a custom built excel spreadsheet to create a leader board. Excel runs on the vMix computer on a third monitor. The background for the excel spreadsheet is green so it can be chroma-keyed out. This comes into vMix using the screen capture input. Its not the most elegant solution, but it works for my needs. If you want to get fancy with your formatting in excel, it can look quite professional.
Speegs
#4 Posted : Saturday, July 11, 2015 1:51:09 AM(UTC)
Speegs
Another option is to write a script in your favourite language, Powershell, VBScript, AutoHotKey (I like powershell). Then make that script inject the data (text) you want to your Vmix title via the web API. Then you just design XAML title for Vmix and use a script + with webapi to populate data. It's like having a second person instantly entering information for you and kind of creepy to watch.
I've found this successful for me of course you need to action something to cause the update of the information from the CSV. It's a bit advanced, should be easier to accomplish however in future versions of Vmix that will include scripting.
Still not perfectly elegant and quite possibly more work than a simple chroma key from excel.
I recently used this "trick" to display the filename (without the extension) of the currently playing video clip in a playlist a title and a few other projects as well with variations on this web api + script controlling it method.
#5 Posted : Saturday, July 11, 2015 4:35:03 AM(UTC)
I send my data from the scoring program (sorted list) to a xml file
The xaml usercontrol at regular interval checks the xml for updates and updates the displays of the list (a binded listview or stackpanel) in the title -> instant update of ranking table
just wish I could integrate some animation during the update ;-)
richardgatarski
#6 Posted : Saturday, July 11, 2015 10:34:25 AM(UTC)
richardgatarski
@Owensoundstudios
Not sure what you are after. But if it's OK with manual loading of the text file you generate, that is pretty straightforward by importing it as a .csv by right-clicking in the Title Inputs preview.
The example you give for content is badly formatted, which might be the cause of you only getting one line. Correct is:
"Bob","80"
"Carry","70"
Speegs
#7 Posted : Sunday, July 12, 2015 8:08:03 AM(UTC)
Speegs
Any chance of posting a sample of that, not you whole project just those actions?
I could learn more about xaml :) it is on my todo list...
#8 Posted : Sunday, July 12, 2015 1:18:10 PM(UTC)
Compiled as a .dll
Sure it can be improved
Just update/add to xml file (externally)and will instantly update the title
Usercontrol.xaml
Code:
<UserControl x:Class="UserControl1"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             mc:Ignorable="d" Width="1920" Height="1080" xmlns:my="clr-namespace:vMixTitleLibrary;assembly=vMixTitleLibrary">
    <UserControl.Resources>
        <XmlDataProvider x:Key="xmlDP" XPath="DocumentElement" />
        <DataTemplate x:Key="BlueHeader">
            <StackPanel Orientation="Horizontal" Margin="-5,-5,-5,-5" Width="550">
                <StackPanel.Background>
                    <LinearGradientBrush EndPoint="0.5,1" StartPoint="0.5,0">
                        <GradientStop Color="#FF223B84" Offset="1"/>
                        <GradientStop Color="#FF57A0F4" Offset="0.5"/>
                        <GradientStop Color="#FF4B94EC" Offset="0.5"/>
                    </LinearGradientBrush>
                </StackPanel.Background>
                <TextBlock Margin="10,10,10,10" Text="{Binding}"
    					VerticalAlignment="Center"  Foreground="Red" />
            </StackPanel>
        </DataTemplate>
        <Style x:Key="alternatingStyle" TargetType="{x:Type ListViewItem}">
            <Style.Triggers>
                <Trigger Property="ItemsControl.AlternationIndex" Value="0">
                    <Setter Property="Background" Value="LightSkyBlue"/>
                </Trigger>
                <Trigger Property="ItemsControl.AlternationIndex" Value="1">
                    <Setter Property="Background" Value="LightGray"/>
                </Trigger>
            </Style.Triggers>
        </Style>
    </UserControl.Resources>
    <!--XPath=runlist[position()\&lt;\4]
        only shows first 3 of the list-->
    <Grid  >
        <ListView ItemContainerStyle="{StaticResource alternatingStyle}" AlternationCount="2" ItemsSource="{Binding Source={StaticResource xmlDP}, XPath=runlist}" FontSize="18" FontWeight="Bold" Foreground="Black" Background="{x:Null}"  Name="ListView1" BorderBrush="{x:Null}" Margin="100,238,1320,142" FontFamily="Arial" ScrollViewer.HorizontalScrollBarVisibility="Disabled">
             <ListView.View>
                <GridView ColumnHeaderTemplate="{StaticResource BlueHeader}" >
                    <GridViewColumn Header="Nr" DisplayMemberBinding="{Binding XPath=NR}" Width="50" />
                    <GridViewColumn Header="Dog" DisplayMemberBinding="{Binding XPath=Dog}" Width="150" />
                    <GridViewColumn Header="Handler" DisplayMemberBinding="{Binding XPath=Handler}" Width="300" />
                </GridView>
            </ListView.View>
        </ListView>
        <ListBox  ItemsSource="{Binding Source={StaticResource xmlDP}, XPath=runlist}" Width="899" HorizontalAlignment="Center" VerticalAlignment="Stretch" Background="{x:Null}" Margin="901,238,120,142" BorderThickness="0">
            <ListBox.ItemTemplate>
                <DataTemplate>
                        <StackPanel Orientation="Horizontal" Height="30" Width="500" Margin="2"  >
                                <GradientStop Color="#FFFFFFFF" Offset="0"/>
                                <GradientStop Color="#FFC5D7F6" Offset="0.683"/>
                        <StackPanel Orientation="Vertical" Margin="2">
                            <TextBlock Text="{Binding XPath=NR}" FontSize="20" Width="50" FontWeight="Bold" Height="50" ></TextBlock>
                        </StackPanel>
                            <TextBlock Text="{Binding XPath=Dog}" FontSize="20" Width="150" FontWeight="Bold" Height="50" ></TextBlock>
                        </StackPanel>
                            <TextBlock Text="{Binding XPath=Handler}" FontSize="20" Width="300"  FontWeight="Bold" Height="50"></TextBlock>
                        </StackPanel>
                    </StackPanel>
                 </DataTemplate>
            </ListBox.ItemTemplate>
        </ListBox>
    </Grid>
</UserControl>
Usercontrol.xaml
Code:
Imports System.Windows.Threading
Imports System.Windows.Media.Imaging
Imports System.IO
Imports System.Xml
Public Class UserControl1
    Private WithEvents m_Timer As New DispatcherTimer
    Private m_LastUpdated As Date
    Private Sub UserControl1_LayoutUpdated(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.LayoutUpdated
        If m_Timer IsNot Nothing Then
            m_Timer.Interval = TimeSpan.FromMilliseconds(500)
            m_Timer.Start()
        End If
    End Sub
    Private Sub m_Timer_Tick(ByVal sender As Object, ByVal e As System.EventArgs) Handles m_Timer.Tick
        InitializeComponent()
         Dim doc As New XmlDocument()
        doc.Load(Path.GetDirectoryName(System.Reflection.Assembly.GetExecutingAssembly.Location) & "\Rankingfile.xml")
        Dim dp As XmlDataProvider = DirectCast(Me.FindResource("xmlDP"), XmlDataProvider)
        '... and assign the XDoc to it, imports the XDoc's root.
        dp.Document = doc
        dp.XPath = "DocumentElement"
    End Sub
End Class
Rankingfile.xml
Code:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<DocumentElement xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
	<runlist>
		<NR>1</NR>
		<Handler>Name 1</Handler>
		<Dog>Dog 1</Dog>
	</runlist>
	<runlist>
		<NR>2</NR>
		<Handler>Name 2</Handler>
		<Dog>dog 2</Dog>
	</runlist>
</DocumentElement>
doggy attached the following image(s):
Speegs on 7/12/2015(UTC)
