Hardware Compatibility
2-AJA Kona 3G cards in Magma Expressbox 3T Expansion
Joined: 10/16/2014(UTC) Posts: 32 Location: San Jose, CA
Hi All!
I was wondering if anyone has successfully installed and used 2- AJA Kona 3G cards in a Magma 3T Thunderbolt Expansion chassis with vMix. It is my understanding with the "quad Firmware" on the Kona 3g, I should be able to get 8 inputs, 6 in/ 2 out, etc. with vMix as long as the inputs are all the same size and framerate.
Thanks in advance! Mike
Joined: 7/9/2014(UTC) Posts: 9 Location: Grass Valley, CA
That is correct. As long as you are using the 4K firmware then it will work in quad mode. If you have any questions feel free to email me directly ericn@aja.comYou are correct on the Kona 3G needing to be same frame rate/frame size. -Eric
