mat.murdock
#1 Posted : Thursday, March 22, 2012 10:09:54 PM(UTC)
mat.murdock
Has anyone tried integrating remote cameras? Say I want to record a basketball game but I want to do the mixing in a different room? How would you suggest I do this? As far as cabling, all I would have access to is a Ethernet or wireless connection.
Thanks,
Mat
#2 Posted : Friday, March 23, 2012 6:56:06 PM(UTC)
If you put your mind to it just about anything is possible.
Your best bet is to run cables but if that is not an option check out this article for running cat5 Ethernet:
http://forum.speakerplan...ethernet_topic30015.html
If you are thinking wireless then the teradek cube might be the ticket:
http://teradek.com/cube.html
I've never tried either, but it might set you in the right direction.
Similar Topics
Multiple remote cameras (NDI)
by BriceMunn 1/14/2021 11:31:19 PM(UTC)
Remote Cameras using Wired Connection Exploration (Hardware Compatibility)
by RichShumaker 6/15/2017 12:24:07 AM(UTC)
