lsfin
#1 Posted : Thursday, June 25, 2015 2:37:15 PM(UTC)
lsfin
When I use the Vcontroller and Vmanager the scheduled video appears, but not with the audio selected. Is there anyway to have the audio automatically selected when the video starts?
#2 Posted : Thursday, June 25, 2015 5:08:49 PM(UTC)
@ Isfin
AFAIK, No (if they are separate files).
The vMixScheduler only loads and plays one 'input' per allotted time slot.
If the video and audio files are separate but need to be associated with one another, perhaps you should look at combining them into a single file that will load and play the way you want with the scheduler.
If they are inconsequential to one another, perhaps you can look at setting up a playlist in vMix that is "Always ON" playing in the background.
lsfin on 6/25/2015(UTC)
lsfin
#3 Posted : Thursday, June 25, 2015 5:22:12 PM(UTC)
lsfin
The video and audio are together. The audio option on vmixer is just not selected, so I have to click it every time a video comes up so it can be heard. How would I get the audio optionto be selected always? @IceStream
#4 Posted : Thursday, June 25, 2015 11:53:11 PM(UTC)
@ Isfin
What are your 'main' audio settings in vMix?
(Settings button at upper right in vMix: "Audio" from menu)
"Automatically Mix Audio" tic box should be activated for 'Inputs' to play audio by default.
lsfin on 6/26/2015(UTC)
lsfin
#5 Posted : Friday, June 26, 2015 2:06:25 PM(UTC)
lsfin
@icestream
It's selected I'm going to try it out, thank you! I'll let you know how it goes
lsfin
#6 Posted : Friday, June 26, 2015 2:56:13 PM(UTC)
lsfin
It worked! Thanks again really appreciate the help!
