Green Outline on Recordings
Joined: 4/19/2014(UTC) Posts: 64  Location: United States Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
We are getting a green outline or frame on the side of our recordings from vMix.
We've tried recording in MP4 as well as AVI.
The line is rather thin but it's there and distracting to the clean look we need.
Anyone else had this issue?
Nick Davidson wrote:We are getting a great outline or frame on the side of our recordings from vMix.
Anyone else had this issue? I solved this issue. Just wanted the community to know incase the issue arose for others. Under the SETTINGS ---> PERFORMANCE, I changed Output Format to RGB32. This gave us a good looking recording in MP4 that removed the green bar on the left side of the screen. I really do not understand the technical aspects of this change but there was an issue recording in the Output Format - UYVY If you can give some insight on this, Martin, it would be much appreciated! Thanks!
