danfybuddah
#1 Posted : Tuesday, June 23, 2015 10:46:32 AM(UTC)
danfybuddah
Hello ,
Please add an option to have Fullscreen on top of vMix window for single display configurations.
thank you .
madness
#2 Posted : Tuesday, June 23, 2015 3:32:29 PM(UTC)
madness
Really? Why? You wouldn't be able to use the actual interface! Are you using an external controller in it's place?
danfybuddah
#3 Posted : Tuesday, June 23, 2015 4:15:50 PM(UTC)
danfybuddah
Yes I intend to control it with a tablet using the web interface and I use vMix as a player (looped playlists with transitions)
Just turning Fullscreen on and off would hide/show the vMix window. Of course it would have to be an extra option to add to the existing "on top" option in display to prevent unwanted disappearance of the vMix window .
If I intend to use vMix , it's because it's the only affordable solution I've found to have seamless loops, seamless transitions, transitions with effects, etc ... Also the web interface is great for playback controls without the need of a keyboard when in Fullscreen.
The other solutions that I've found are VJing softwares that are way too complicated and expensive for my purpose.
If you guys know of a better solution , please feel free to share it !
