Issue with "opening preset"
When i open a saved preset, with lined up videos and images, videos won't appear on the preview window nor the output window, however images come up fine.
I use only videos (about 30" each) and images for projection, in total about 30 files. All works fine, but it forces me to input them all every time i need the preset.
Any help is appreciated. Thanks Carlos
Joined: 1/13/2010(UTC) Posts: 5,293  Location: Gold Coast, Australia Was thanked: 4665 time(s) in 1607 post(s)
Hi Carlos,
Can you provide a screenshot that displays this issue?
Thanks,
Martin vMix
Hi Martin, Thanks for answering... Here's a screenshot of how it comes when i open a saved preset. screenshotThanks Carlos
Thanks,
What graphics card and cpu does your computer have?
Martin vMix
Hi Martin,
Dual core AMD athlon 64 X2 TK 57 1900 MHZ card: ATI Radeon Xpress 1250 (256 Mb)
Looks like you have reached the memory limit of your graphics card. If you load more videos than the graphics card can handle then some windows will show up blank or will flicker.
I would recommend a better graphics card or load the videos into the "Video List" option which loads them as needed rather than all at once.
Martin vMix
Hi Martin,
Thanks for your help! Carlos
