cutter07
#1 Posted : Sunday, June 14, 2015 6:41:16 AM(UTC)
cutter07
I tried a higher network buffer value in FFMPEG Streaming Window in vMix, but it seemed that it has no effect at all.?
When I open the protocol (view status ) the command line option "-bufsize" for ffmpeg is fix set to -bufsize:v 500k (half of bitrate).
#2 Posted : Sunday, June 14, 2015 12:26:09 PM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
The Network Buffer is not related to the bitrate, see the documentation below:
http://www.vmixhd.com/help15/StreamingQuality.html
cutter07
#3 Posted : Sunday, June 14, 2015 2:38:20 PM(UTC)
cutter07
Honestly I didn't understand how it works. Means Network the local Network LAN?
