cutter07
#1 Posted : Sunday, June 14, 2015 9:31:47 AM(UTC)
cutter07
In this case vMix streaming the wrong stream to FFMPEG:
#2 Posted : Sunday, June 14, 2015 12:24:39 PM(UTC)
Was thanked: 4674 time(s) in 1609 post(s)
That is correct, the tick boxes only apply to multi-bitrate profiles, that is ones with more than one box ticked.
If you are only streaming a single bit rate, the top one will always apply.
cutter07
#3 Posted : Sunday, June 14, 2015 2:25:46 PM(UTC)
cutter07
No problem for me, now :)
I never thought about it,
since we ran in some bandwidth trouble
I unchecked then simply the first and last stream to get a single stream...thinking way is the bandwidth still so high?
Regards Silas
