saxonytv
#1 Posted : Tuesday, June 2, 2015 5:50:24 AM(UTC)
saxonytv
Hi @all,
is it possible to unregiser vMix 15 on a specific PC when we want to move the installation to another PC with a different hardware configuration?
Or should we completely uninstall the software in this case and the uninstaller takes care that the license information is updated with the vMix license server (so that we need a working internet connection when we uninstall our vMix HD license on the old PC)?
We already know that it is possible to make a backup installation on a second PC but we want to work straight ahead and want to unregister all software instances which we do not use any longer.
Thanks for your feedback.
André
wwdv
#2 Posted : Tuesday, June 2, 2015 3:39:58 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
You can register vMix on more then one PC, but you can run vMix on only one PC at the same time.
So just uninstall it.
