Streaming issues and error messages
Joined: 5/26/2013(UTC) Posts: 148  Location: Houston, TX, US Thanks: 28 times Was thanked: 6 time(s) in 6 post(s)
I searched but found nothing....regarding vMix HD 15.0.0.78 x65:
I am attempting to do 2 simultaneous streams, a WMV and a Flash and am running into issues. I am using vMix to do both at the same time. These errors happen regardless of whether both streams are started...that is, if only one is running...
1. any attempt after starting vMix and the streaming to change the WMV streaming parameters gives a "streaming port is currently in use" error. (I am using currently using port 8080). A close and open fixes this - once per open. Am I better off using WMEncoder?
2. when attempting more than one RTMP stream, I get nothing. Also, if I try to do the second and/or third - nothing. Only 1 stream from the first "quality bit rate" box works.
Suggestions?
