cutter07
#1 Posted : Sunday, May 31, 2015 9:16:54 AM(UTC)
cutter07
It would be nice to have a special transition between "Virtual Inputs". The transition should smoothly change the parameters like Zoom, Pan, Rotate, color.
richardgatarski
#2 Posted : Tuesday, June 2, 2015 12:53:30 PM(UTC)
richardgatarski
Not sure if I understand, but it looks to me like what you are after is almost the same as my Feature Request on MultiZoom transitions. That is you want a smooth zoom between the different virtual cameras.
But I think, with the exception for the color parameters, that you could obtain what you want using a Virtual set with your camera as the only layer and define different "angles" for the zoom, pan, and rotate.
#3 Posted : Tuesday, June 2, 2015 2:15:36 PM(UTC)
@ cutter07
I agree with Richard that you can do this with the supplied "Blank" Virtual Set, which will give you 3 different camera zooms that you can customize as need be by right clicking on the camera thumbnails.
Which kind of brings us to another of Richard's feature requests:
http://forums.vmix.com.a....aspx?g=posts&t=3135
that could possibly make this process a little easier to set up.
cutter07
#4 Posted : Wednesday, June 3, 2015 2:36:59 PM(UTC)
cutter07
Virtual Set is not usable for our needs, because we need live preview from every "Virtual Camera" also we need fast setup.
The first video is how we setup the virtual inputs live, to find a nice camera clip:
Virtual Input Live Setup
The second video shows the "feature request" result:
Feature Request Result
