#1 Posted : Monday, May 25, 2015 11:01:10 AM(UTC)
In playing around with the Virtual Sets, (as discussed here)
I am wondering if there is a "Shortcut" for each camera view? (Close up, medium shot and wide)
I was not able to find one.
I don't tend to use the Virtual Sets, but if I did, I would want to use the keyboard and not the mouse to change 'views'.
The closest I could find was "SetMultiViewOverlay" but that merely changes one overlay channel input in 'MultiView'
(really neat glad I found that)
I realize the list of "Shortcuts" is growing all the time and I thought perhaps this one already existed (maybe it does, I just haven't figured out which one).
In any event, for those using 'Virtual Sets', I think the addition of such shortcuts would be beneficial.
#2 Posted : Monday, May 25, 2015 11:44:36 AM(UTC)
Have you tried function "Zoom" Ice ?
Guy
#3 Posted : Monday, May 25, 2015 12:08:17 PM(UTC)
@ doggy
Thanks for the insight...
Actually, the 'Zoom' transition is not correct, but using 'Fade' does work to transition zoom with 'Virtual Sets'.
How cool is that!
I knew the 'Shortcut' must have existed.
#4 Posted : Monday, May 25, 2015 12:14:24 PM(UTC)
@ Ice
so they both work on virtual sets ??
they both seem to do the same here at least
#5 Posted : Monday, May 25, 2015 12:56:31 PM(UTC)
@ doggy
Not exactly sure, for me the 'Zoom' transition zooms out to 'infinity' and then back in to full screen (which is what I would expect).
The 'Fade' transition performs the same as clicking one of the camera views and zoom transitions to that view (which is a little counter intuitive).
In any event, I'm glad you pointed me in that direction and figured out the 'solution'.
richardgatarski
#6 Posted : Tuesday, May 26, 2015 11:35:44 AM(UTC)
richardgatarski
Not sure how one would use "Fade" (or Zoom).
In any case, isn't it the "SelectIndex" shortcut that you are after?
#7 Posted : Tuesday, May 26, 2015 6:57:13 PM(UTC)
@ Richard
I tried the "SelectIndex" function, but I don't know the correct parameters (Input,Value) and vMix returned an "Invalid Parameter" error message for anything I typed.
I don't know why the "Fade" function works but it does and it appears to be designed this way as it is a more directed way than the "SelectIndex" (options in dropdown menu) so I am inclined to 'GO with it' as a simple and effective solution.
shaiz
#8 Posted : Friday, December 18, 2020 12:29:57 AM(UTC)
shaiz
the select index works perfect.
in the index\value box,
just add the number of of the box (4 of those) you want to put on air.
