givros
#1 Posted : Friday, May 22, 2015 6:13:20 PM(UTC)
givros
Hello
Can you help me with a case. I need to do a Multi Language Streaming to one CDN.Has anybody done it before and can anybody help me with this case?
Thank you
richardgatarski
#2 Posted : Saturday, May 23, 2015 8:55:45 AM(UTC)
richardgatarski
I have not done it. AFAIK it is not commonly supported.
My interest (for many years) have been to simultaneously send the original audio and audio descriptions (kind of voice over for people who are visually impaired).
An alternative solution would be if vMix could send two (or more) streams, in this case with different audio.
Our current fix is to use a separate streamer (vMix PC) where the audio descriptions are mixed with the original sound. (We will actually do that on May 26, 13:00 - 15:00 CEST, at https://pts.solitango.com)
I think that if you have control over the CDN (eq a Wowza solution) you can build or implement a live player that controlled which of the two audio channels (left/right) that should be played out. In other words, in vMix you make sure that left is language A and right is language B. Then the player offers a setting to play left or right audio, or rather language A or B.
Please let us know how you proceed.
OChamps
#3 Posted : Tuesday, May 26, 2015 3:03:50 PM(UTC)
OChamps
I am in the same situation where I have to stream the same content in two languages. I have to stream it twice off the same system. I stream directly from vMix in the primary language and select vMix output and the secondary language input in Adobe Live Media Encoder.
