15 Pages«<1011121314>»
g-mo
#221 Posted : Tuesday, November 18, 2014 6:31:16 PM(UTC)
g-mo
That folder is located at C:\ProgramData\vMixScheduler
The only files inside are the settings xml and the vMixSchedule xml
macjaeger
#222 Posted : Tuesday, November 18, 2014 6:36:52 PM(UTC)
macjaeger
hmpf.
I guess i'll have to install a virtual windows 8 in order to test it...
One more thing you could try: remove the two xml-files from the scheduler folder and try again - though i have little hope this would help.
thanks 1 user thanked macjaeger for this useful post.
Ademola Tella on 11/14/2018(UTC)
g-mo
#223 Posted : Tuesday, November 18, 2014 6:41:32 PM(UTC)
g-mo
Its working!
I hadn't moved the debug version into the proper folder.
THANK YOU!
g-mo
#224 Posted : Tuesday, November 18, 2014 6:53:09 PM(UTC)
g-mo
One final question if you dont mind....
How do I adjust manager to program for the entire file length? The clips are cutting with 1 second remaining.
pilgrims1
#225 Posted : Friday, November 28, 2014 12:16:05 AM(UTC)
pilgrims1
Recently, When I test on vMix 14 version with your scheduler.....
testing connection is good...
but connection is not established....
Can I use your scheduler with New version ?
macjaeger
#226 Posted : Friday, November 28, 2014 9:03:30 AM(UTC)
macjaeger
Latest version is http://www.weir3d.de/fil...uler/alpha_07_14_102.zip
This should work with vMix 14 - at least until they change the web-api again...
It's not thoroughly tested though, i just changed the part that prevented the programms from connecting. There may very well be additional changes that i didn't find in my short testing.
thanks 2 users thanked macjaeger for this useful post.
clair on 2/24/2015(UTC), Ademola Tella on 11/14/2018(UTC)
titanium
#227 Posted : Tuesday, January 27, 2015 9:44:27 PM(UTC)
titanium
Good night. I need help. vMixScheduler connects seamlessly with Vmix 14.0.0.106, but after an hour I get a message and disconnects, then do not send any video, I have to restart the computer to get it working again. Is there any soculcion to my problem ?, please help me.
"going offline because of event in Addinput(). The remote server returned an error: (500) Internal Server Error."
macjaeger
#228 Posted : Wednesday, January 28, 2015 8:45:20 AM(UTC)
macjaeger
Please test if you can (still) connect to vMix' web-interface with your browser; it looks like vMix itself has a problem, like the error messages says: the remote server (= vMix) returned an error (=> vMixController works and receives messages): "internal server error" (that's what vMix told vMixController).
You should not need to restart your whole computer, restarting vMix should resolve the problem (unless vMix crashes and then occupies the port).
Also please check if your system is running stable and has enough free memory and/or disk space, especially on c:\ .
dagarrison on 2/15/2015(UTC), Ademola Tella on 11/14/2018(UTC)
clair
#229 Posted : Tuesday, February 24, 2015 9:33:45 AM(UTC)
clair
thank you for update scheduler.
and can i get your source code?
macjaeger
#230 Posted : Thursday, February 26, 2015 10:03:06 AM(UTC)
macjaeger
sure.
http://www.weir3d.de/fil...heduler/vMixScheduler.7z
this should contain everything, but i must admit that i haven't looked into it in months... so if you miss something, just contact me again!
have fun!
mac
thanks 4 users thanked macjaeger for this useful post.
madness on 2/27/2015(UTC), clair on 4/9/2015(UTC), vedranius on 4/29/2015(UTC), Ademola Tella on 11/14/2018(UTC)
pilgrims1
#231 Posted : Sunday, March 8, 2015 1:38:49 AM(UTC)
pilgrims1
I hope....
Overay control can be scheduled.....
with much more control... ^^
clair
#232 Posted : Thursday, April 9, 2015 11:20:21 AM(UTC)
clair
i need someone's help.
i using vMix15 and scheduler(latest).
it working good, but cannot load audio files.(other filetypes are OK)
in normally, file will load to vMix befor 5sec at scheduled time.
but any audio files(i tryed .mp3, m4a), they did not load to vMix.
10:00:00 video1.mpg <- loaded and runned on time
10:01:00 music.mp3 <- didn't load
10:02:00 video2.mpg <- loaded and runned on time.
Is there a solution for this case?
Bruno Silveira
#233 Posted : Sunday, May 17, 2015 9:13:24 PM(UTC)
Bruno Silveira
I put in vMix and the ip is 192.168.1.15:8088 more in the Controller when I test it in ta 127.0.0.1:8088 and I can not connect programs . how can I fix . Thank you.
[img][/img]
Bruno Silveira attached the following image(s):
resource (1).png (35kb) downloaded 4 time(s).
#234 Posted : Monday, May 18, 2015 12:56:19 AM(UTC)
@ Bruno Silveira
Is it safe to assume you are running vMix, vmixControler and vMixManager on the same computer?
Bruno Silveira
#235 Posted : Monday, May 18, 2015 1:40:03 PM(UTC)
Bruno Silveira
I'm having a problem do not know if is to help me. I've got two computers on the network, with ip 192.168.1.5 ( Controller ) and another with ip 192.168.1.6 ( Vmix ) when I ask to connect it tries to connect ip 127.0.0.1:8088 and does not connect , I can not change this ip , but when I open the browser and type in the address 192.168.1.6:8088/controller it works perfectly , ie it connects and works , only the ip that vmixcontroler of me I would have to change it if it does not. Thank you.
Bruno Silveira
#236 Posted : Monday, May 18, 2015 1:43:45 PM(UTC)
Bruno Silveira
I am using 2 notbook wifi , browser, it works. Vmix the control of another computer over the vmixControler not connect .
PC vmix.png (35kb) downloaded 2 time(s).
PC vmixcontroler.png (357kb) downloaded 5 time(s).
#237 Posted : Monday, May 18, 2015 3:28:44 PM(UTC)
@ Bruno Silveira
To the best of my knowledge, vMixScheduler needs to be running on the same computer as vMix.
http://compnetworking.ab...sses/g/127_0_0_1_def.htm
bunayya01
#238 Posted : Sunday, July 12, 2015 11:39:39 PM(UTC)
bunayya01
why vmix controller can't connect to vmix.. status always offline..
but in test port is responsive withe same port 8088..
thanks before
dagarrison
#239 Posted : Thursday, July 16, 2015 5:24:32 PM(UTC)
dagarrison
Looking at the source code for vScheduler and being a novice at C#!! I was able to create a config file have vMixManager pull the path to the server I run my station on. It takes a few lines of code however it is possible to run the controller on your broadcast machine and the scheduler on the other.
The only problem I have is right now I am not aware of which program was used to create the program since I get a error when it makes a call to media info. So I must use the original Manager and the updated control written by another user which also needs to be modified to play a default program when file is not found.
If I knew more about C# I would compile and re-share the source with my changes. In test it works great not having to be on the actual machine building a schedule!!
thanks 2 users thanked dagarrison for this useful post.
ghayden6 on 7/21/2015(UTC), Ademola Tella on 11/14/2018(UTC)
ghayden6
#240 Posted : Tuesday, July 21, 2015 11:35:37 PM(UTC)
ghayden6
Can vMix producer try to install something like vMixScheduler in their vMix product. I like the idea behind the scheduler. Is there any other scheduler that can be used?
Guest (4)
