Ario
#1 Posted : Wednesday, April 29, 2015 5:48:30 PM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
Dears,
I have really looked & searched long and hard within vMix (15) itself, but I just can't get it to work:
is there a way to keep the LIVE audio (a mic, plugged into the pc's mic-in port) running, while at the same time showing a replay?
So the wish is: viewers of the livestream hear the 'present' sound, even though they see a replay of somewhat earlier.
At the moment, during a replay, they get no sound at all.
I would like for them to hear the audio of the action (basketball game) as it unfolds live, all the time, so also when a replay is shown. The sound as recorded with the replay moment, does NOT need to be replayed.
I must be overlooking something ...?
Thanks so much in advance,
kind greetings,
Arie
#2 Posted : Wednesday, April 29, 2015 9:09:00 PM(UTC)
@ Ario
Short answer: YES!
You are best to read through the following thread where the answer is discussed and illustrated:
http://forums.vmix.com.a....aspx?g=posts&t=3539
Ario
#3 Posted : Thursday, April 30, 2015 8:50:25 AM(UTC)
Ario
Dear Ice (hockey ? ;-))
thanks so much.
Quoting from your tip there:
"How are you 'inputting' the commentator's audio?
If you want their audio ON all the time, set up that audio input to be 'Always ON' in the Audio Mixer or with the "Audio" button under that input.
If you want the 'Replay' to also include the "original" commentary, you will have to set-up your Replay recording appropriately (note: this is fine for highlights but not very good for 'slow motion' replay, you are best to 'mute' the Replay audio for that while "live", 'Audio Never ON')."
I will try that indeed !
thanks so far,
most kindly,
Arie
