Adriankey4
#1 Posted : Wednesday, April 29, 2015 9:53:42 AM(UTC)
Adriankey4
Jamaica
Hello. This is urgent.
I use vMix on my PC and now I want to buy a PC to use the AJA 4K but I am worring if the device can connect over mini D.P cause I don't want to buy a laptop over US$800. Is it possible?
#2 Posted : Wednesday, April 29, 2015 10:33:42 AM(UTC)
@ Adriankey4
Can you elaborate a little bit more?
What AJA 4k device?
Purchase of laptop or PC?
I guess the point is, what exactly are you trying to accomplish?
Adriankey4
#3 Posted : Wednesday, April 29, 2015 12:42:36 PM(UTC)
Adriankey4
Jamaica
Its the AJA Io 4K which uses Thunderbolt. I want to buy a laptop with mini DP but I am asking if the thunderbolt connection can work in the mini DP
richardgatarski
#4 Posted : Wednesday, April 29, 2015 12:48:37 PM(UTC)
richardgatarski
Rank:: Advanced Member
If you need Thunderbolt, you need Thunderbolt.
DP is not Thunderbolt.
https://support.apple.com/en-us/HT204149
#5 Posted : Wednesday, April 29, 2015 1:18:40 PM(UTC)
@ Adriankey4
Richard is correct, although you are not the first to be confused;
http://www.cnet.com/news...ayport-with-thunderbolt/
Thunderbolt would be the 'way to go', not just for the sake of the AJA Io 4K, but also other alternatives and expansion boxes:
http://www.sonnettech.co...t/thunderbolt/index.html
http://www.magma.com/
Which will permit much more versatility, expandability and 'future proofing' for your laptop...
Adriankey4
#6 Posted : Wednesday, April 29, 2015 1:37:24 PM(UTC)
Adriankey4
Jamaica
ericn
#7 Posted : Saturday, May 2, 2015 5:40:55 PM(UTC)
ericn
That is correct. Display port is carried as part of Thunder 1 and 2, however display port is not thunderbolt.
If you have any questions about AJA hardware feel free to email or call AJA at anytime. We are happy to answer questions!
sales@aja.com
or try
+1-530-274-2048
Thanks,
Eric
AJA Video Systems
