zentriloquy
#1 Posted : Monday, April 20, 2015 4:57:05 PM(UTC)
zentriloquy
For an upcoming gig I need to be able to record the show in HD, but also need to stream to a computer in another room. The room is over 100 feet away with numerous doors, walls and corners in the way. I did get streaming over a lan working, but at low resolution, the suggested 640X360, and this would work fine for the feed. But now how can I record at full HD resolution at the same time?
Sorry if this is a newbie question. I am working as fast as I can to get up to speed with this software. It is KOOL! Likin it, but as with all technologies there's a learning curve. I have to be operational for Tuesday.
Thanks for any help.
#2 Posted : Tuesday, April 21, 2015 10:35:09 AM(UTC)
@ zentriloquy
This should work for you since both 'Stream' and 'Record' features have independent settings, the caveat will be how well your system handles it all.
You are best to test adequately, as I am sure you are in he process of doing.
