One License for Desktop and Laptop
Joined: 1/13/2010(UTC) Posts: 5,338  Location: Gold Coast, Australia Was thanked: 4741 time(s) in 1627 post(s)
Yes you can install a license on two machines as long as both are not being used at the same time.
Martin vMix
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
Is it also possible to install it on more than 2 systems? Because my employees need to test/learn the program, before working on a live production and I can't afford to buy 3-5 licenses only for testing.
 1 user thanked Rinsky for this useful post.
Joined: 5/27/2013(UTC) Posts: 28 Location: Battle Creek, MI
Rinsky wrote:Is it also possible to install it on more than 2 systems? Because my employees need to test/learn the program, before working on a live production and I can't afford to buy 3-5 licenses only for testing. Can they run the trial if all they need to do is test/learn the system? I am running the free license on my laptop for testing purposes. It does give limitations but for testing and learning it is fine. Kirk
 1 user thanked petraproductions for this useful post.
Joined: 1/5/2013(UTC) Posts: 36   Location: Jamaica Thanks: 102 times Was thanked: 3 time(s) in 3 post(s)
admin wrote:Hi,
Martin vMix Kool, but what u mean they can't be on the net or server at the same time? Adrian
Adrian,
Only one copy of vMix is permitted to be open at one time with one license. So it is a against the license to start it up on a second machine if it is running on the first.
Martin vMix
Joined: 5/26/2013(UTC) Posts: 148  Location: Houston, TX, US Thanks: 28 times Was thanked: 6 time(s) in 6 post(s)
admin wrote:Adrian,
Martin vMix please clarify - so to run vMix on one PC and Desktop capture on a remote PC, I need two licensed copies of vMix, one per machine? "The computer you wish to capture will need a copy of vMix installed and the vMix Desktop Capture program will need to be running on that computer." Thanks
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Quote:please clarify - so to run vMix on one PC and Desktop capture on a remote PC, I need two licensed copies of vMix, one per machine? "The computer you wish to capture will need a copy of vMix installed and the vMix Desktop Capture program will need to be running on that computer." HWL asks an excellent question here. Could the answer become a sticky?
