j1mco
#1 Posted : Thursday, March 19, 2015 2:24:08 PM(UTC)
j1mco
Is anyone using an AJA io4k over Thunderbolt?
I'd like to confirm that 4 concurrent capture via SDI/HDMI is possible within vmix? (there are mixed descriptions/information on the internet)
Ideally we'd use 3x SDI 1080p30 and 1x HDMI 1080p60 all simultaneously.
If this is possible, is it possible via Thunderbolt v1 and v2?
Thanks!
j1mco
#2 Posted : Tuesday, March 24, 2015 5:12:08 PM(UTC)
j1mco
Bump... anyone? :)
#3 Posted : Wednesday, March 25, 2015 9:23:23 AM(UTC)
Yes, the AJA io4k is supported and you can use all four inputs simultaneously.
Note that HDMI will need to be used as Input 1, but you can then use the 2,3 and 4 SDI ports for the others.
Thunderbolt v2 is recommended when using 60p sources. p30 or 60i sources will work well with both
j1mco on 3/25/2015(UTC)
vedranius
#4 Posted : Thursday, April 16, 2015 10:35:00 AM(UTC)
vedranius
Tell me, when you say simultaneously, will it work with all type of cameras, fullHD, UltraHD and 4K? Or?
As I'd like to have 4x fullHD cameras connected to Aja io4k and adding them to vMix and mixing them, not only switching between them.
When you said that HDMI will be used as input 1, does that mean that then you are only left with 3 HD-SDI inputs working? And the first one then doesn't work?
Thank you!
