I need help, I have a vc440e card, my pc is Core 2 Duo 2.6, 4GB ram, when I try to capture, in the dialogue are the entries for the card, but when I give OK to capture freezes the computer, and I have to force a shutdown. it can be? I'm trying to Vmix 2012, also tried with other programs mix of video cameras and frozen. Thank you for your help.
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
I install drivers but new and the problem follows equal, is congealed the PC. some other suggestion
Rank: Guest
what operative system are you using on that machine?
