Stavlin
#1 Posted : 10 years ago
Stavlin
Was thanked: 6 time(s) in 4 post(s)
Anyone else had an issue where using ReplayExportLastClip results in a clip that is 2-3 seconds too short? Generating the clips from within vMix generates files of the correct length but the API command always generates a short file for me.
Cheers,
Joe
thomas
#2 Posted : 10 years ago
thomas
Yes, I also just noticed that. A one-minute clip were exported and resulted in a 48 seconds-clip while using the API-command..
Cheers,
Joe
bucsatul
#3 Posted : 10 years ago
bucsatul
I've noticed the same issue while using shortcuts. The exported clip is shorter and the sound is not sinchronised anymore.
It's completely different when using the export clip button in the InstantReplay window. Than it's all ok.
It's the shortcut that doesn't work.
Emil.
