GeorgeR
#1 Posted : Sunday, March 29, 2015 3:26:03 PM(UTC)
GeorgeR
Was thanked: 30 time(s) in 28 post(s)
vMix 15.0.0.68x64 (Windows 7x64)
When I open the vMix streaming advanced settings window in my Windows 7x64 computer I no longer see the usual settings options for setting the backup server as in past versions. The image below are the only settings allowed.
I rolled back vMix in the Windows 7 computer to version 14 and the normal advanced window appeared as in past versions of vMix.
This is not true in my windows 8.1x64 laptop. The same advanced window appears in version vMix 15.0.0.68x64 as with past versions.
GeorgeR attached the following image(s):
vMix 15.0.0.68x64 stream backup settings.PNG (57kb) downloaded 0 time(s).
#2 Posted : Sunday, March 29, 2015 6:08:01 PM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
Hi George,
The backup settings are not available when using FFMPEG as the application, which is now the default.
To see them switch it back to FMLE.
GeorgeR on 3/29/2015(UTC)
