vMix Social and Playlist with title template including in- and out-transition
I'd like to build a small setup, where vMix automatically uses content from vMix social (twitter) and runs that in a loop. Problem is, that the title template has in- and out-transitions, which I'd like to appear (ideally) on every new entry coming from vMix social.
I added two inputs: 1 with title template 2 with transparent color
-> added both to a playlist which has looped & clear overlays ticked and both inputs have Display Type: overlay 1.
I tried different settings in vMix (on inputs like restart with transition and pause etc.), but never got the right result.
What is the right way of doing this task??
Any help will be appreciated!
Version: 15.0.0.66
I researched some old information (thx to studiotech live) and it seems to me, that I can answer my own questions now as follows:
Running content with in/out transition (same as ticker from vMix live) is just not possible at the moment.
Joined: 4/25/2014(UTC) Posts: 41  Location: Norway Thanks: 2 times Was thanked: 18 time(s) in 10 post(s)
You basicly want a tweet to appear once it's tweeted, stay there for a few secs then disappear? This is possible using the API and a Custom XAML file
Cheers Sondre, developer at Shop.njastad.com
