Titles resolution and overlay
Hi, I have a problem with the titles and overlays in the sense that you see on the monitor output badly, and also on the monitor output of blackmagic, any suggestions? Thank You hardware configuration: I5 8 gb ram win 7 hd 4600 graphics card intel motherboard asus Z87 Blackmagic intesity pro
Rank:: Administration
Joined: 1/13/2010(UTC) Posts: 5,338  Location: Gold Coast, Australia Was thanked: 4741 time(s) in 1627 post(s)
This usually means the Output Size in settings is set to a low resolution.
Thanks for the answer, but I have to send the output signal to an encoder in SD, so I put in the output parameters 720x576 25 frames, right? thank you
If you will be outputting to SD then 720x576 is correct and as it sounds like the monitor is much higher resolution it is not going to look HD quality, so the lower quality is expected and is normal.
so if I go out in hd I improve the quality? and then go out from the encoder to 720x576 sd? thank you
