computerman1597
#1 Posted : Thursday, March 19, 2015 6:48:58 PM(UTC)
computerman1597
How would this HP ProDesk work for up to 2-3 Cameras at 720p vmix, along with a single remote desktop capture and a few images/lower thirds graphics?
http://www.tigerdirect.c...o=8925380&CatId=2627
It would all be running in 720p, with recording and possibly SD streaming in the future.
computerman1597
#2 Posted : Thursday, March 19, 2015 7:38:33 PM(UTC)
computerman1597
Also, does anyone know if this AverMedia card:
http://www.amazon.com/Av...s=avermedia+hd+component
is compatible with vMix? I have done some searching on the internet but haven't found anything regarding directshow compatibility. I did find this forum entry that seems to indicate that someone has been able to use it with Wirecast:
http://forum.telestream....id=44&threadid=14268
Should anything that works with wriest also work with vMix?
ask
#3 Posted : Friday, March 20, 2015 12:44:53 AM(UTC)
ask
Was thanked: 199 time(s) in 181 post(s)
Not guaranteeing this but I don't think it supports DirectShow. http://www.avermedia-usa...aspx?Id=482&tab=FAQ.
I suggest you look at the C127 http://avertv.avermedia....roductDetail.aspx?Id=565
computerman on 4/8/2015(UTC)
computerman1597
#4 Posted : Saturday, March 21, 2015 7:11:07 PM(UTC)
computerman1597
Thats what I was afraid of, thanks. It would've been a really cool option if it worked.
Any opinions on the computer, I think it should work but I don't want to buy a computer that is underpowered immediately.
computerman
#5 Posted : Monday, March 30, 2015 2:28:20 PM(UTC)
computerman
I may have found a better PC option. http://www.amazon.com/HP...keywords=core+i5+desktop
Its $420, has a quad core i5 and 4GB of ram. Also has enough pce express and pci express x16 slots for 3 capture cards and a graphics card. I am thinking with the money I would save I could buy a graphics card and more ream when I needed it. Would whats there plus a good graphics card be enough pc to support 3 Hd captures and a few other inputs?
computerman
#6 Posted : Wednesday, April 8, 2015 9:22:14 AM(UTC)
computerman
Can anyone confirm if it is possible to use multiple C127 cards in the same machine, provided that you have enough card slots?
ask
#7 Posted : Wednesday, April 8, 2015 11:07:25 PM(UTC)
ask
Yes.
computerman1597 on 4/16/2015(UTC)
