Hardware Compatibility
Blackmagic Design Ultrastudio Mini Monitor Playback Device
Blackmagic Design UltraStudio Mini Monitor Playback Device this card works with vmix? http://mlb-s1-p.mlstatic...20236373488_012015-F.jpgdjagnaldo attached the following image(s):  blackmagic-design-ultrastudio-mini-monitor-playback-device-22780-MLB20236373488_012015-F.jpg (97kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
Joined: 9/8/2014(UTC) Posts: 244 Location: Southaven MS
Thanks: 12 times Was thanked: 26 time(s) in 21 post(s)
This device is basically providing you an additional monitor (either HDMI or SDI) through a Thunderbolt connection. Are you trying to add another monitor for your vMix? If so vMix should certainly detect is as an available monitor to display to. I don't think it will serve any other purpose than that.
Tim
