adrian_pro
#1 Posted : Tuesday, March 17, 2015 2:58:09 PM(UTC)
adrian_pro
Hello
I have a question. is there any possibility to generate an output on a portrait mode?
Do I have a possibility to rotate it 90 degrees?
Or any script to load to do that?
Bardos
#2 Posted : Tuesday, March 17, 2015 6:05:57 PM(UTC)
Bardos
Groups: Guests
I don't know if I understand you correctly, but you can rotate any image in vMix....Click on the little cog for settings, select position, and you will see at the bottom, 'X' , 'Y'. 'Z' ....use the 'Z' to rotate your image any degree you need, and the 'x' and 'y' to move the image left or right, up or down.....you can zoom with the first one at the very top.....play around til you get the hang of things and you are good to go.....
thanks 1 user thanked Bardos for this useful post.
adrian_pro on 3/18/2015(UTC)
