Slideshow images, timer problems
Joined: 3/16/2015(UTC) Posts: 5  Location: The Netherlands
When using a slideshow with images, I have some timing problems;
When a slideshow is set in the preview, it waits nicely before playing (or can be 'reset' to the first image). Starting the slideshow (the very first time it seems to work a time fine.
But when transition takes place any next time, the first slide does not have the entered wait-time and could go to the next image right away, or after just some (random?) seconds, in stead of the entered duration time. It seems a "timer reset on transition" is missing here.
If I skip a image/slide by the "|<<" or ">>|", the duration-timer is not reset, too. A time-reset would be expected here as well when skipping a slide back or forwards. Now the next slide can be shown very shortly; it uses the previous timing of the (skipped) slide before.
And while we are in this slideshow subject, I have a minor remark; Intuitively I think the field label names in the slideshow settings 'Transition' and 'Duration' are swapped....?
Thanks!
Best regards,
Diederik
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
Hi Diederik,
Thanks for the feedback, in the next 15 update I will make sure the timer is reset when moving from preview, restarting and starting/pausing.
As for the potentially confusing naming, it is designed to be consistent with the rest of vMix where Duration is almost always in reference to the duration of the transition effect, but I take your point that it could be made clearer.
Martin vMix
