Joined: 10/1/2013(UTC) Posts: 196  Location: Bovalino (Italy) Thanks: 86 times Was thanked: 3 time(s) in 3 post(s)
can you tell me what's the trigger the url, backup server, live in youtube? Besides consuming upload bandwidth
thanks
Not exactly sure what you mean by "what's the trigger the url", but if you are asking why you would want to stream to both the primary and backup YouTube servers, I think it's in case the primary server has issues. I used to only stream to the backup server because of repeated problems with the primary. In my case, I don't have the upload speed to stream to both the primary and the backup at the same time.
Mike
Thanks Mike. I thought I would serve for you to Youtube save a copy of the event, then I realized that he did the same. I also do not have enough bandwidth for upload on both servers. Thank You
Antonio
