donnyyeo
#1 Posted : Wednesday, February 8, 2012 12:40:40 AM(UTC)
donnyyeo
Hi, I am still testing vMix 60 days trial.
I am looking for a budget composite video capture card. ( less than USD250 )
Does this card works well with vMIX?
BlueCherry TW-220 - 8 port video capture card (240FPS) - Realtime recording, PCIe (Windows 64bit support!)
• It uses the TechWell TW6868 video decoder chip
• Support Windows 7, 32 and 64bit
• PCIe interface
• Unlike the PV-155, PV-981-8 or PV-981-16 each port of this card will show up as a separate WDM device, allowing you to use all inputs with Directshow applications.
webware
#2 Posted : Saturday, March 3, 2012 12:13:26 PM(UTC)
webware
Hello
I hope this is not too late. Do not buy Bluecherry cards for video purposes because they do not hold up well. They are good for low FPS (surveillnce cameras) but not SD or HD media.
donnyyeo
#3 Posted : Tuesday, March 13, 2012 9:29:47 AM(UTC)
donnyyeo
webware, which BlueCherry card did you used?
I have not buy the card yet.
Still researching for a good budget card which works well with Win7 64-bit.
Please share your findings if you found a solution.
